Posted by Michael Soldan on May 13, 2008 at 15:12:51 from (24.235.58.254):
In Reply to: H trans leaking posted by Lon-Mo on May 13, 2008 at 12:44:37:
Take that plate off, you will see two shafts that drive the trans and the belly pump, getting the pump out is a bit difficult, remove the bolts in the shaft and set it aside. Turn the flange where it is leaking out, counter clockwise, pick out the seal and tap a new one in place and reassemble..a few hours on Saturday morning and its done...lots of H's don't leak until the trabs is properly filled and then they leak..very common...as stated , check the archives, all the info you need to fix the problem..couple of hours at the most
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
