Well it is hard to tell for sure, we need more info. If the tractor is equipped with a TA (very likely) it could be a part of the problem. If the TA lever is forward, then the TA clutch could be bad allowing the TA to slip. It would act like it was able to slow down some, but be able to pull when it got to TA speed. (partially slipping) If it flat will not move, there could be broken parts in the TA assembly, or other issues. What procedures did the "mechanic use to determine the clutch was OK? The TA is a Great Asset to the tractor, and should be repaired if it is broken. A possible real cause of the symptoms you describe are improperly adjusted TA/and main clutch linkage. There may be nothing wrong. The Book is needed to adjust a TA correctly, (no seat of the pants adjustments are usable until you get to the point of extreme experience The Tractor Vet, or a gent on here, Mier, among others, who have that experience. Good luck, let us know. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
