Model 400 transmission or rear end
Posted by Douglas Cochran on May 14, 2008 at 06:24:29 from (66.20.144.205):
I was driving across the field when the tractor simply stopped pulling. I thought the clutch had gone out completely but when the mechanic checked it he said the clutch was okay. What would be the most likely cause - transmission or rear end? Is there a common failure of a particular part or something hopefully simple like a nut coming off a shaft that would mimic a worn out clutch?
