Re: unburnt fuel
Posted by IH454 on May 14, 2008 at 16:13:09 from (71.60.32.245):
In Reply to: Re: unburnt fuel posted by IH454 on May 14, 2008 at 16:09:28:
The most noticeable smoke seems to be at idle, but almost has to be all the time, the glasspack is pretty loaded up
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
