Re: unburnt fuel
Posted by old on May 14, 2008 at 17:33:00 from (4.245.7.181):
In Reply to: Re: unburnt fuel posted by IH454 on May 14, 2008 at 16:13:09:
Idle jet works back wards by the way. turn it out to lean it out and turn it in to make it richer. As far as the main jet if it has an adjustable one it should be low on the carb. Turn it in to lean it out and out to make it richer. But not all carbs have an adjustable main jet and if thats the case about the only way to fix it is replace the main jet its self
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
