Posted by Kevin Meier on May 14, 2008 at 18:04:07 from (64.71.85.247):
In Reply to: Re: 560D TA slipping posted by scenic acres on May 14, 2008 at 17:03:05:
when you get the t/a out you may need to also machine your ramp roller surface on the 361281 carrier. And also the seal surface just under the t/a flywheel splines. With a .010 oversized roller the ramp area should measure 2.858 or higher and the seal surface should measure 2.933 or higher. Any other questions my email is open.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
