Re: WIRING A FARMALL 300
Posted by the tractor vet on May 15, 2008 at 06:17:52 from (76.212.230.0):
In Reply to: WIRING A FARMALL 300 posted by MAGMAN on May 15, 2008 at 05:36:45:
Ya have any of the old harness to work with???? If ya do then use my trick of building a new one . I use a 2foot by 8 foot piece of plywood and lay out the old harness on it and use finish nails to hook the old wires streched out and hook the ends over the nails . Then strip off the cover and see what color wire and size of wire and mark it on the board . IF it has and alt. i use a 10 Ga. for the main wire from the hot post of the alt. to the amp gauge then from the amp gauge to the starter . Then after i have all the layout work done i remove the old harness and start laying out the wires to each nail on the board . Myself i use uninsulated ends then i use a real good heat shrink over the ends or terminals to give the factory look . IF ya have wires that were broken off the org. harness then leave them long and finish them once on the tractor for the correct length . One trick that i do for a generator to alt. change over is i use a cv relay to energize the alt. and forget the ligthbulb or diode . As for the wire loom after years of tracing it down i found a wire supply house that i could get the factory style loom and with practce one can make a real factory look to it .
