Re: Farmall A Mower Bogging Down
Posted by Paul Shuler on May 15, 2008 at 08:17:14 from (170.29.248.3):
In Reply to: Farmall A Mower Bogging Down posted by Whitley County on May 15, 2008 at 08:04:46:
I have a cub that has a lot less power than your A and it can mow ankle deep grass all day long in 2nd and not break a sweat. I think a good sharp edge on those blades should make a big difference.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
