Couple thoughts; Valves were way out of adjustment and one cylinder low compression. Have you made sure valves aren't sticking? Are you getting enough fuel to "flood" the plugs? Are you getting a hot blue spark at the plugs? We have had a running engine with a hole in one piston, another that burned so much oil it looked like a diesel under full load. Step back and look at ignition/timing/fuel delivery, it should run, maybe poorly. I've driven some into the shop and taken them apart and wonder how they could have functioned at all.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
