Allan: It will leave the 10" grass a bit ragged the first pass, but you'll have nothing higher than 6" and most of it will be mower setting height. Like Jerry says it's got to be sharp.
If my mower is the least bit dull, quite often I'll get a wiff of hot belt. If I shut her down and belt and pullies are hot, I know those blades have lost their edge. It's not my belt loose either, it's tight as a fiddle string. In 6 years, I've yet to see my SA loose RPMs when mowing. Now, I grant you most of the time one could almost shave with the blades. I will not tolerate dull blades.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
