Andy, I posted about the manifold being bad on the last post. I having been trying to think of a way that you might check it on the tractor. Try pulling the rocker assy. off so all the valves are all closed. Next take a shop vac. set it up to blow not suck. Duck tape the hose into the exhaust pipe. Open the throdle and don't put the choke on. Now turn on the vac if it blows air out the carb you have a hole or a crack in the manifold somewhere or it could be a valve leaking if you pull the plugs you could tell what cylinder the valve is leaking in. my guess is #1 cyl. if the valves are what is wrong. Try tapping the one that's leaking with a brass hammer and spray lube to get it to seat. Once it seats you will need to reset your valve adjustment on it or it will be too tight. You said there was a blockage in the intake what was in there? I glad you reposted I've been wondering if you got it going. DO NOT GIVE UP ON IT!
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
