Re: ADVICE!!! On Removing 46yr, Threaded Exhaust Pipe...
Posted by iowa 100 on May 15, 2008 at 21:26:59 from (207.42.19.227):
In Reply to: ADVICE!!! On Removing 46yr, Threaded Exhaust Pipe... posted by charles todd on May 15, 2008 at 18:53:46:
we've done this many times. with manifold removed, cut pipe off leaving half up to an inch outside manifold. then just use a cutting torch to cut down into manifold. The old pipe cuts out quick, cast does not cut and if you cut properly, as one should be knowledgeable, the heat will not damage the manifold. Two cuts, hammer and chisel the the two pieces, out in about 10 min.
