Re: Frustrated with H
Posted by Andrew Z on May 16, 2008 at 18:30:56 from (76.231.243.143):
In Reply to: Frustrated with H posted by Tom Windsor on May 16, 2008 at 18:16:57:
Do you have good fuel flow to the carb? you might have an air lock or debris in the line or in the carb its self, i would check that out first, one of the simplest things to start with anyway. also check your carb adjustments too.
p.s. I know that your in CT just to let you know there is going to be a pull/show at the 4 towns fair grounds sumers CT. tomorrow and Sunday. the pull is tomorrow. generally a good little show and pull. hope the weather clears
Andrew
