Posted by Brownie 450 on May 16, 2008 at 19:17:10 from (216.51.158.151):
In Reply to: Frustrated with H posted by Tom Windsor on May 16, 2008 at 18:16:57:
I forget who it was that checked the float level/ gas level in the carb by taking the drain plug out on the bottom of the carb, & putting a hose barb in it's place. Then attach a piece of clear plastic hose & wire it up beside the carb leaving the top end open. This will let you check the float/ gas level. If it has enough gas in the carb, & has good fuel delivery, you can look at another area to see if that may be causing trouble. For instance--plugs/ wires, or points/ condenser. Could be a gummed up jet or foreign material got in the fuel delivery tube.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
