Re: HELP too much oil pressure
Posted by RJV on May 17, 2008 at 04:08:36 from (75.179.27.97):
In Reply to: HELP too much oil pressure posted by RJV on May 15, 2008 at 17:03:08:
I just took the head into a machine shop to get looked at. I figured that is the one for sure thing I know is wrong so Ill see what they find then go from there before tearing into the oil pump. I also did a compression test before the head came off. I got 90, 50, 25, 50 Lbs on the individual cylinders. Could the compression loss be because Im pumping compression into the block which is being shown on the oil pressure gauge??
The bright side, fired up the cub for the first time this year, mowed 2 acres with it, without any problems. Its good to have a spare tractor sometimes.
