Re: battery terminal meltdown today- stuck solenoid??
Posted by ironandsteel on May 17, 2008 at 18:55:57 from (12.26.114.108):
In Reply to: Re: battery terminal meltdown today- stuck solenoid?? posted by GordoSD on May 17, 2008 at 18:42:09:
I know they are supposed to be 6v. There are currently 2 12v batts on there (6 month old JD strongbox- great batteries), in series for 24v. The former owner mistakenly assumed that this was supposed to have 24v. And the gauges aren't hooked up anyway, so it works. And you don't run the starter long enough that it will get fried.
I'm planning to wire them in parallel for 12v and wire up a delco alternator.
