Re: farmall h shifting problems
Posted by Don L C on May 18, 2008 at 07:26:16 from (24.33.90.217):
In Reply to: farmall h shifting problems posted by david mccord on May 18, 2008 at 06:01:26:
david ---
Before you pull the top cover (heavy),knock the pin out of the shift lever (put it in nutrial) first...lift lever out,bottom of lever should be about 1/4" wide and 5/8"long no groves.....look where it fits and build it up with welder and grind it to easy fit......
Now that I have started this I cant remember to well, its been a while......somebody else will help.......Don
