Re: wet sleeve question/blown head gasket
Posted by Charles E. McNelly on May 18, 2008 at 18:01:28 from (72.18.77.252):
In Reply to: wet sleeve question/blown head gasket posted by RJV on May 18, 2008 at 17:29:46:
I think you need the slight lift on the sleeves to seal the compression rings on the head gasket. When you replaced the head gasket did you torque it to 80 lbs, then retorque it after you ran it? If you didn't it will suprise you when you do. I got another 1/4 turn when I retorqued mine. Good Luck,
Charles
