Posted by Janicholson on May 19, 2008 at 07:55:18 from (64.83.197.92):
In Reply to: MD White Smoke posted by Peculiar Farmer on May 19, 2008 at 07:41:09:
Your description is of an MD that needs to be worked some. THe slobbering of oily junk means it needs to be brought up to twmp under load for an hour or so. If it has a High Compression needed for diesel operation. That requires a Diesel compression tester, and pulling the injectors. If it has not been run, and is n ot missing radically on one cyl. I recommend getting buisy with it pulling something hard enough to work it. It is a worki ng tractor, and is not really adaptable for short small light loads. Good luck, JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
