Re: Charrlynn power steering question
Posted by Steven f/AZ on May 19, 2008 at 14:14:24 from (216.67.213.217):
In Reply to: Charrlynn power steering question posted by Redstate on May 19, 2008 at 13:06:09:
I believe the max pressure for the torque generator is 1000 psi.
A good belly pump (later model) will have 850 psi. The belly pump will work fine for power steering, but don't expect to lift/lower implements and steer at the same time, even with a flow divider. The GPM of the belly pump is a little short to run multiple things at once.
