I think it would be difficult to reinstall the pistons from the bottom since a ring compressor is required. Those sleeves & crankshaft need to be measured for wear. If the engine has a lot of hours you should pull the engine since you will probably need cam bearings and this determines good oil pressure. The ring ridge needs to be removed with a reamer. Hal
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
