farmall engine repairs
Posted by charley123 on May 20, 2008 at 09:24:06 from (70.243.78.150):
Can a person swap out the pistons/rods on a farmall M from underneath? Drain oil out, remove oil pan, remove the bearings from below, rotate the crankshaft, lower the rod/piston out the bottom and replace with new one? trying to skin a cat.
