Simple answer is no. Ya you might get them out but not back in. Plus the ridge as the other said would need to be removed it it can/will brake the new rings, plus the crank should also be checked for true. You might get by with new rings, rod and main bearing but why take the chance and end up with no engine at all because if the crank needs work it could throw a rod out the side of the engine
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
