C -block with cracks between coolant holes
Posted by Steven M on May 20, 2008 at 13:55:15 from (67.59.61.220):
I have a C (1948) with cracks in the block between the coolant holes similar to the description given by "riverbend" in an earlier response. The cracks starts between the coolant hole (carburetor side) located between the first and second cylinder, runs to the 2nd cylinder hole then to the middle coolant holes then to the third cylinder hole and appears to stop at the coolant hole between the third and forth cylinder. The tractor was not in running condition when I started the rehab project. The radiator was full and the condition of the antifreeze looked to be clean. I could not detect any antifreeze in the oil when I drained it. I am planning to take the block to a machine shop and thought that they could magna flux the block for additional cracks and then grin into the cracks and weld. Based on the conditions, I described can the block be repaired? What am I looking regarding cost? Any recommendations on how to best to proceed?
