Re: Inhaling exhaust on cub?????
Posted by Scott Rukke on May 20, 2008 at 18:02:19 from (67.183.230.71):
In Reply to: Inhaling exhaust on cub????? posted by Mifsud on May 20, 2008 at 17:47:16:
Take off the valve cover and check the valve adjustment. Also check the firing order and timing.
