Re: removing 1949 M pistons
Posted by John A. on May 20, 2008 at 20:17:02 from (138.210.118.138):
In Reply to: removing 1949 M pistons posted by H fanatic on May 20, 2008 at 18:06:37:
H, Hopefully your tractor is in an open place, if not get it outside,
2 remove gas tank and other flammables from the area.
Next, one cylinder at a time.... "hope each piston is in the lower part of the sleeve" fill the cylinder up with Diesel add a splash of gas,
3 set on fire! let it burn itself out,
4 See if you can them drive out the pistons. if the piston doesn't become free after the fire, repeat prosedure. Especially if piston is near the top of stroke. the fire will usually free up the piston the first or second time.
Hope this helps!
Later,
John A.
