removing 1949 M pistons
Posted by H fanatic on May 20, 2008 at 18:06:37 from (205.188.116.73):
I have a 1949 Farmall M and the pistons are stuck really bad. I took the head off and got rid of most of the rust. I took the pan off the pan today and found a large surprise. RUST EVERYWHERE! Got the rod off and took cylinders 2 and 3 connecting rods of the crank. I was able to beat on cylinder 2 and pushed the sleeve out about a 1/2 inch. I can't get the others to budge what can I do to free cylinders 1,3,4? I have brake fluid in them now, but I was wondering if there was a better technique. I was going to take a bottle jack and try to press them out. What is also the best way to separate the sleeve from the piston?
Thanks,
Nick
