Posted by Dave BN on May 20, 2008 at 22:37:51 from (64.12.116.73):
In Reply to: Farmall A S/N posted by Ron in OH on May 20, 2008 at 18:17:32:
Yep, looks like 1940 A. If no starter then most likely you don't have a choke rod that goes back to the operators area either. With magneto ignition these tractors are easy to start with the crank if the timing is set properly. Dave
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
