Re: Adjusting front end on IHC 140
Posted by Hugh MacKay on May 21, 2008 at 02:07:17 from (216.208.58.115):
In Reply to: Adjusting front end on IHC 140 posted by Chuck Edler on May 20, 2008 at 18:53:41:
Chuck: No: there is the same coresponding adjustment on tyrod as on the axle. If you have two holes exposed on the telescoping axle then you must have two exposed notches on tyrod. Same with 3 and 3 .
Your suggestion of 55" is technically 56. Sounds to me as though you may have it set at 52" on front, with front wheels dished out.
