Re: removing 1949 M pistons
Posted by gene bender on May 21, 2008 at 03:11:43 from (67.55.226.69):
In Reply to: removing 1949 M pistons posted by H fanatic on May 20, 2008 at 18:06:37:
If its that rusty i would pull the engine/ Now with the engine out you can press them out and also you will be able to see the rest of the engine and be able to clean the block. So quit wasting time as you will have to pull the crankshaft also and cam and lifters. You mite even junk it out if thers rust everywhere but you cant realy see everything until the engine is out. So get busy and it sounds like it could be quite a project.
