Re: Super M Clutch: Rejoining Tractor
Posted by smith1000 on May 23, 2008 at 02:35:19 from (12.213.112.39):
In Reply to: Super M Clutch: Rejoining Tractor posted by Smith1000 on May 20, 2008 at 17:49:09:
All good advice. I will be working on this today. Come to think of it, I have a plastic clutch alignment tool that came with a clutch kit for a truck I worked on. It may work. I had not thought of turning the PTO to rotate for alignment. I hope it goes back together easily. Thanks
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
