Re: IH 424 Stuck in Reverse
Posted by Janicholson on May 24, 2008 at 07:54:42 from (64.83.197.92):
In Reply to: IH 424 Stuck in Reverse posted by IntHarv on May 24, 2008 at 07:31:28:
Bob is correct. Pull the lever and realign the shift rails in the trans with a big screw driver. This is common. If it has a worn pin holding it in, make a new one from a grade 5 bolt cut to the right length. if the pin is good, the tip of the shifter that enters the rails may need to be welded up a little and ground to fit better. there are pictures in caseih.com, and in the search for area here. Let us know if it helped. JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
