Re: 1086 TA / Clutch
Posted by bemhoff on May 24, 2008 at 19:35:10 from (98.21.93.215):
In Reply to: Re: 1086 TA / Clutch posted by Chuck's Repair on May 24, 2008 at 19:10:59:
Yep it comes on. I was thinking the same on the pressure. I will admit that I don't know a lot about the tractor ie. what the MCV pump supplies and stuff like that. This is the first time any of this happened and I am the kind of person that likes to fix little issues before they become big ones. This all happened around idle to 900 rpm so I would assume if the pump was getting weak it would not be building the correct pressure. I would assume that there is a pressure regulating valve in the system and it could be sticking. None of that would explain the the slight gear running noise that I was hearing. Thanks for your response.
