Re: Super M Hydraulic Reservior
Posted by Janicholson on May 25, 2008 at 06:50:01 from (64.83.197.92):
In Reply to: Re: Super M Hydraulic Reservior posted by Bob M on May 24, 2008 at 19:50:02:
Bob, I think he will also need to take off the coupling cover behind the pump. allowing access to the drive coupling. I also wonder if putting an old piece of Hydraulic hose on the filler stand pipe would allow some directional control? A woden (jorgensen) type clamp could be loosened or tightened to keep some tension on the top of the pump! JimN
