5288 hydraulics
Posted by tj in iowa on May 25, 2008 at 09:43:13 from (67.1.120.135):
Having problems with my hydraulic remotes. If I lift up my disk, get out of the tractor, open gate, get back in, its is already down on the ground. Put on my sprayer and the wings each have one hose, they drift up and down when going through the field. Is there an adjustment, or do I need new valves or what. All 3 remotes seem to act the same way. Thanks for you help. Also I am having a few problems with the sentry. Sometimes the tractor won't move, and you have to push clutch in and back out again, then it works fine for a while. I am thinking it is one of the pressure switches, are they hard to get at, should I replace both of them?
