Posted by RODGEinIL on May 25, 2008 at 11:11:38 from (64.136.26.231):
In Reply to: 5288 hydraulics posted by tj in iowa on May 25, 2008 at 09:43:13:
I can't answer the hydraulic question but I just had the same problem with the sentry on my 5488. There is two pressure switches under the floor pan in the cab. Kinda a pain to get at.. got to remove the mat, etc. You can switch the pressure switches from one to another to see if the problem is the odd numbered gears or even numbered. Easy to see if one is bad will be seeping/leaking oil.Also the sentry module has two relays on the bottom, switch these to see where the problem gears will be. Just swap them side to side. If any of this doesn't work the module could be bad. The module is in the fusebox at the bottom center of the dash, between the clutch and brake pedals. Sorry for the long post hope it helps!
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
