Re: Reversed H or M
Posted by NDS on May 25, 2008 at 17:55:15 from (64.12.116.73):
In Reply to: Re: Reversed H or M posted by Hugh MacKay on May 25, 2008 at 17:15:33:
Hugh if you get a chance pull oil fill plug on M and look at ring gear and visulize where it would be if it was flipped and you will see that it appears there is no way that it would clear shifter. I have reversed a couple and did not actually try to set top on without moving shifter but have been told by some pretty good old cotton picker mechanics that shifter will not clear. Have seen a lot of posts on this forum by people trying to find 2 hole top for M to make high clearance show tractor out of high drum cotton picker M.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
