Re: Reversed H or M
Posted by Hugh MacKay on May 25, 2008 at 17:15:33 from (209.226.247.135):
In Reply to: Re: Reversed H or M posted by NDS on May 25, 2008 at 16:44:36:
NDS: My 560 worked without moving the shift rails. Note I put it in reverse to back out of the shop and to my surprise went forward. (refer to my earlier post) Now maybe the number series were different but it has always been my understanding the shift lever was changed to give one the same shift pattern seated the other way on tractor. I know that is how the 300U forklift I moved was set up.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
