Posted by Jim Broughton on May 25, 2008 at 19:00:10 from (4.243.5.55):
In Reply to: 1942 H questions posted by farmerwannabe on May 25, 2008 at 18:30:32:
Wow !! Sounds like the wiring is about gone on 'er...If you can, take your jumper cables and put the positve cable to ground...put the negative to the battery cable post on top of the starter.Turn yo ur switch to on and try that if she turns over, you've got wiring problems,if not check the "box" starter cable unit and make sure it touches the copper spade on the starter, also check to make sure cable nut on starter is tight..they have a habit of working loose ! Good luck !! Jim B.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
