Re: Farmall 400 won't start
Posted by teddy52food on May 27, 2008 at 06:15:49 from (209.237.111.169):
In Reply to: Re: Farmall 400 won't start posted by El Toro on May 26, 2008 at 16:16:42:
You have got that backwards. The S gets hot from the ign switch when cranking. It should have no voltage when the engine is running. The other (I) terminal bypasses the resistor to give full voltage to the coil while cranking. When it is running the I terminal will show the voltage after going through the resistor. An old 6v ford type solonoid will have a hot terminal which is grounded to complete the crank curcuit.
