Posted by Bob M on May 28, 2008 at 18:41:11 from (69.205.114.144):
In Reply to: farmall h steering gear posted by donald schnupper on May 28, 2008 at 17:02:25:
Don - Like the others point out a small amount of vertical play - less than about 1/2" or so - is normal. More than that can mean the pivot shaft thrust bearing has failed.
To check the condition of the thrust bearing jack up the front end. Now look for wear on the bolt heads that attach the lower bolster to the pivot shaft flange, and from the bolt heads rubbing on the underside of the fixed bolster casting. Also look for wear on the steering gearbox cover from the pivot shaft nut rubbing on the underside of the cover.
Either of the above means the thrust bearing needs to be replaced. Otherwise don't worry about the vertical play!
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
