Re: How to check compression on diesel engine
Posted by billde on May 30, 2008 at 16:24:13 from (72.26.91.191):
In Reply to: How to check compression on diesel engine posted by Brad in WI on May 30, 2008 at 15:34:02:
keep the injectors in, close the decompression valves, check just like it was a gasser. Bleed off fuel beforehand.
