How to check compression on diesel engine
Posted by Brad in WI on May 30, 2008 at 15:34:02 from (24.208.60.64):
What is the easiest way to check the compression on the diesel side of an MD. I know using a gauge for a diesel is a good start but how would I insert it into the injector hole and have minimum leakage. Any advice on this is good advice as I am stumped. I can check it on the gas side by threading into the spark plug hole and checking like that. I will not get a reading with out the diesel injectors in place though and they are removed currently.
