Re: How to check compression on diesel engine
Posted by the tractor vet on May 30, 2008 at 17:17:01 from (76.212.239.147):
In Reply to: How to check compression on diesel engine posted by Brad in WI on May 30, 2008 at 15:34:02:
To do a proper comp. test ya have to remove the injectors clean the injector well and have the proper fitting that looks like a injector and use a new sealing ring and torque it in just like you would when ya install the injector. then you hook up your gauge and turn the engine over. Then move to the next hole.
