Re: How to check compression on diesel engine
Posted by Janicholson on May 30, 2008 at 20:42:54 from (64.83.197.176):
In Reply to: How to check compression on diesel engine posted by Brad in WI on May 30, 2008 at 15:34:02:
Find or make an adapter that will allow your Gas compression gauge to be placed in the Injector hole.
Leave the plugs in, set it to gas side operation and crank it All pressures will be equal in a closed system, so it will be as if the injectors are in. JimN
