Re: Checking out my new H., weak pump.
Posted by Charlie M on May 31, 2008 at 05:41:06 from (70.101.104.228):
In Reply to: Checking out my new H., weak pump. posted by Calif. Farmall on May 31, 2008 at 01:06:47:
Couple of things on the belly pump. Those pumps had an upgrade that increased the pump pressure. If the one you are looking at didn"t have it done it won"t lift as much. Also can try heavier oil, at least 30wt. Had an IH mechanic tell me to try 40wt in my M. After that you may just have a pump with too much wear or possible junked up inside.
