Re: Timing the magneto
Posted by Dr. Bert on June 01, 2008 at 17:30:00 from (72.36.57.176):
In Reply to: Re: Timing the magneto posted by El Toro on June 01, 2008 at 14:49:06:
Hal: I treated the pump the same as I would the mag--trying to align it's gear mark with the cam gear mark- #1 on TDC and the pump lugs pointing to 2 o'clock as I would the mag. Then set the mag to fire at #1 and installed it. The engine started, but isn't right. Runs best with the magneto retarded as far as it will travel. Am I off 1 tooth on the pump gear?
