To find out how much you're off is to bring No1 piston to TDC on the compression stroke again. Your timing mark on the damper pulley should be aligned with pointer, then remove the mag's cap and then see where the rotor is pointing. It should be pointing to the No1 plug tower. If its off you will need to pull the mag and place the rotor at the No1 plug tower. Then see if it runs ok. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
