Thank you for the information! Yes, the water pump was easy to remove, especially with the radiator removed, it needs a good flushing and the rubber cushions replaced anyhow.
Luckily, none of the bolts were frozen, and with a little patience removed easily.
Found the correct pump for the engine through a supplier on this site and have ordered it! In this day and age, trying to find someone to press that shaft and bearing is far and few between, especially in our area!
Will still be researching to find the exact model and year of this tractor, as there is other items that need attention. I have a good background in mechanics, just limited on the tractor side of things.
This tractor has been sitting idle for 3 years, and amazingly started and ran very smooth. Clutch and transmission function properly. Have not tried the PTO yet.
Give it a good flushing, fluid and filter changes and should be good to go! Having the proper model information, is important to me, to make sure I use the proper fluids in the trans and differential.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
