Farmall 140 front axle tube rotating problem.
Posted by Randy Dragoo on June 01, 2008 at 19:46:51 from (208.127.203.115):
Has anyone had problems with the 140 front end adjustable axle tubes rotating inside one another? I've tightned the axle clamps that pinch the tubes together, but it still isn't tight enough. This of course allows the inner tube to rotate and the spindles go backwards slightly. Mine must have been loose with the previous owner, because I see the locating pin is slightly wallowed out. Thanks to the group!
Randy
